Prado 90 1kzte wire diagrams
timmay556
Post by timmay556 »
Anyone have a link for the wire diagram for the dash on a Prado 90 1kzte (auto)
My speedo is cutting in and out causing the engine check light to come on (is this bad?) I've checked it a the transfer case and all is well.
Re: Prado 90 1kzte wire diagrams
there might be one on www.pradopoint.com
wsnownz
Post by wsnownz »
Did you get this sorted? Having the same problem
timmay556
Post by timmay556 »
nah havent been able to track it down.
1kztejameschch
Newbie
Newbie
Post by 1kztejameschch »
Hey there myn does this to sometimes im new to the 1kz got a lj78 and done conversion was a misson changed dash and everything got some stupid questions its a 1kzte bloody big transfer case does anyone no how many leters of oil and what to use in her as gona do my self bloody get ripped off in christchurch 9 times outa 10 they ovee fill in under cheers
kbushnz
Post by kbushnz »
1kztejameschch wrote:Hey there myn does this to sometimes im new to the 1kz got a lj78 and done conversion was a misson changed dash and everything got some stupid questions its a 1kzte bloody big transfer case does anyone no how many leters of oil and what to use in her as gona do my self bloody get ripped off in christchurch 9 times outa 10 they ovee fill in under cheers
Transfer Case takes a little over 2 liters.
Basically on level ground, fill it to it overflows out of the fill hole.....Which is on the back of the case... about 1/3 of the way up. Looks just like the drain plug.
If you run a pto, it will take a but more.
