wtd landcruiser extended shackles
hello24
Post by hello24 »
am looking for a small lift for the bj74 just want to know a good place to get a cheap set of extended shackles or if any one has some lying around for sale.
will be using factory springs for now do i need anti inversion shackles?
thanks
Disco Gofer
Re: wtd landcruiser extended shackles
Post by Disco Gofer »
I have a 40 with 200mm extensions but made them for my bush truck. I also welded some angle iron just behind the front shackle to stop them from inverting. But you can find these on Ebay.com.au and would take a week to get from Brisbane.
hello24
Post by hello24 »
yea they are cheap on e bay but $150 in shipping..... do i need the anti inversion ones? found these on tm http://www.trademe.co.nz/motors/car-parts-accessories/parts-other-makes/suspension/auction-656785440.htm
what do you think
reddog40
Post by reddog40 »
On the front you definitely need anti inversion shackle stops, especially if you extend the shackles. I wouldn't recommend using longer shackles in the front unless you want even more vague steering.
