Purchased it back in May planning on building a new winch truck, but plans have changed so it has been sitting in the shed up until now.
So my plans now are to get it up and running to use as a club truck and something I could drive to work if needed.
The basic run down on what's been done:
Coil suspension all round, Prado front diff, Surf rear
V6 Commodore engine and auto, Marks 4wd adaptor and Hilux transfer case
Body work has had panel and paint done.
So started earlier in the week, first thing to do is get the chassis rolling. Started with the front Prado diff.
Stripped it completely down to check the condition and find out what ratio the diff is.
Cleaned all the parts up ready for some new paint
Sprayed all the parts this afternoon,
Also dropped the chassis off to the sand blasters this afternoon, has a lot of surface rust should hopefully get it back by the end of the week.
So that's where I’m up to so far, tomorrow will assemble the front diff and probably start on the rear Surf diff.
Cheers Thor
