Roof mounted spot lights
alvis
Post by alvis »
Hi Guys, i am in the process of wiring up my new roof mounted spot lights for my fj40. Someone told me that it would be a wof failure having more than 2 spotlights? . This will obviously affect how i wire them up so any advise on this woule be greatly appreciated. Will they need to be removed for a wof?
Cheers - Alister
niblik
Post by niblik »
if possible, make the roof mounted spotties attach to the bar in such a way as the bar, with spots, is removable... get a plug like connection you can have 'in cab', and attach when the grunt of the spotties is needed.. might be handy if off roadin and low branches threaten ya new requisition.. :wink:
possibly plausible?
p.s.. go the 40's...!! :thumleft:
jumper
Post by jumper »
i had 4 lights mounted to a bar that was bolted to a roof rack bar so it could be taken off for trees or using the roof rack and had a plug that hooked up to a short amount of wire with a plug on the end sticking out of the roof. worked great :D
mercutio
Post by mercutio »
are there issues with roof mounted spots for certification
i know you are not supposed to have more than 3 pairs of lights on the front of your vehicle
iand i was under the impression roof mounted are an issue here for some silly reason
alvis
Post by alvis »
Thanks for the replys guys. I will wire up a plug just as it exits the roof so that i can remove the whole bar, which is not that hard as it has a roof rack attachment thingy. Jumper did you ever take your truck for a wof with the lights on the roof?
There was an existing hole in the roof so i used that and then fed the wire down the hole inside the top of the windscreen and through the heater vent to the switch keep it all looking stealth.
niblik
Post by niblik »
stealth is good...
nothing like the attention to detail when moddin trucks.. :D
Tuxy
Post by Tuxy »
hella makes a good product the supper sealed conectors unfortuanitly you need a proper tool for installing them
alvis
Post by alvis »
Thanks tuxy, for the moment it is a choc box with insulation tape but i will look into the hella one to tidy it up.
wjw
Post by wjw »
Why not use a standard trailer coupling? Another option would be the waterproof connectors repco do... they work ok
Who knew Prados could fly?
Tuxy
Post by Tuxy »
Yea but try to stay away from repco they are far to overpriced
The trailer connection is a good idea but go for the round ones I think they are hella part numbers #4012 and #4011 off the top of my head as the square ones don’t seal as well as the round ones.
But what you really want is hella part number #4907 and #4908 as you can flush mount the female end to your roof and then plug in the male part when you use it.
http://www.hella.co.nz/?t=9&pcid=264
http://www.hella.co.nz/?t=9&pcid=300
Hope those are some help
i must say from my experience the hella gear is far better than anything else I have used it just has that feeling of quality that I like (bit like my snap-on tool addiction):)
alvis
Post by alvis »
Thanks mate.
wjw
Post by wjw »
Tuxy wrote:Yea but try to stay away from repco they are far to overpriced
They look good, know who would stock them?
Tuxy
Post by Tuxy »
probaly not in stock but they can be overnighted out of hella so check out this http://www.hella.co.nz/?t=172 for your local reseller any of them will be able to order in the parts
mercutio
Post by mercutio »
i´ve never really been a fan of hella myself
always thought it was overpriced myself
great fan of narva though
alvis
Post by alvis »
Let there be light :evil: :evil: :evil: :evil:
mroffroader
Post by mroffroader »
looks pretty efficent to me...:reminder to self: must buy some spotlights :lol:
Return to “Tool Shed”
