Who is the guru race pump builder !!
I have a rather large turbo manifold ,external etc on my td42 with 11mm plunger pump and im wondering who is the best in nz for building race pumps with bigger plungers and higher lift cams etc , ?
Prefer someone that builds them for race engines and that has done a lot of them ,
Trundle
Trundle
Re: Who is the guru race pump builder !!
PM dumbass on here, her man is the man when it come to TD pumps. Has built more than a few over the years
Try Diesel Services in Napier there is a guy there who is very good with TD42's
his name is Errick
his name is Errick
Turbo Diesel and Automotive in Hamilton do some insane race pumps for TD42. Their demo/workshop run around LWB Safari needs to be driven to be believed
Its not hard to do it yourself. A bit daunting but all the info is out there. Once you have done it then take it in and get it calibrated
mds kaipoi,chch,talk to hayden
meatc wrote:PM dumbass on here, her man is the man when it come to TD pumps. Has built more than a few over the years
Aaron been out of the pump building game for a while now. He is enjoying racing his instead...
Speaking of "race" pumps,,, where the hell are all these race td42s?
I want see them before I build one.
wax wrote:Its not hard to do it yourself. A bit daunting but all the info is out there. Once you have done it then take it in and get it calibrated
I know this sounds rude, but. How is it not hard if you have to take it to a diesel tech to calibrate it?, That is not doing it yourself.
Sorry to be rude, but the time they spend at a test bench is the important bit
Drive as fast as you can, NOT as fast as you can not.
I agree its not all doing it by yourself but alot of the stuff that takes the time can be done by you. Its like building an engine and then taking it to the dyno. You still technically build the engine.
I build race engines etc but the time factor does'nt really happen when you run a buisness ,
wax wrote:I agree its not all doing it by yourself but alot of the stuff that takes the time can be done by you. Its like building an engine and then taking it to the dyno. You still technically build the engine.
Sorry I miss understood. I thought a dyno was a machine that converted hocus pocus into numbers, giving you the power,torque,revs blah blah numbers to see if your modifications changed anything......dynos don't tune....Tuners use dynos..
A test bench is to test fuel flow and set pump timing,,, If the man setting these does not know what he is doing, your engine will suffer greatly and you will be very angry..
Trundle wrote:I build a lot of race engines etc but the time factor doesnt really happen when you run a buisness ,
Fricken Sweet, What sort of racing do you build your TD42s for? and how much?. I want a faster one than Aaron.
Hahah not diesels man
Damn. Thanks anyway
Td42s are a temperamental creature.
Bit like your devils work rotarys
Dumbass wrote:wax wrote:I agree its not all doing it by yourself but alot of the stuff that takes the time can be done by you. Its like building an engine and then taking it to the dyno. You still technically build the engine.
A test bench is to test fuel flow and set pump timing,,, If the man setting these does not know what he is doing, your engine will suffer greatly and you will be very angry..Trundle wrote:I build a lot of race engines etc but the time factor doesnt really happen when you run a buisness ,
Im sorry you were not able to understand. You take it to the dyno tuner. Not often does the guy tuning the car actually build the engine or machine it etc
Sweet,
Can you tell me the settings you provide? and where they came from?
Dumbass wrote:Sweet,
No I will not you will have to work them out yourself.
Seriously mate your not the only one who has rebuilt a ve4 pump. Quit the better than thou attitude.
On another note if you do rebuild your pump have a look here and you will see where I have ported the pump to help it flow.
It kinda doesn't make sense until you pull one apart and have a good look at the lift pump and how badly mis matched it is
http://www.offroadexpress.co.nz/Forums/ ... &start=120
wax wrote:Dumbass wrote:Sweet,
Steady on, I have never built a pump ever (where did you get that from?)......I was going by the fact you said it was easy and I could do it myself.... It sounded good to me.
Oh so I was reading it wrong then. My apologies I took your attitude for bad attitude. If it sounds good to you just ask your partner.
Sorry about that, I shall keep searching,
Thanks again.
Thanks again.
Ahhaha. Making new friends I see Dumbass.
You definitely come across as Holier than thou in this thread.
Stop talking about building a truck and build a truck.
Don't take it all personally Wax. In real life she actually a good person.
Hahahahahah!!! Good person!!! Ohh that's priceless. I can just see sticky choking on her coffee reading that!! bwahahahaha
Hahahaha. Good call.
My coffee suffered the same when I read a race td42 was easy to build.
Any way, I am always the poor bitch that gets grief from the high and mighty td42 lunches who think it is funny. Just because of who I hang out with........so I am sticking up for the poor td42, Personally I hate the things. And I am Just trying to save a few engine from pub legends and google builds.
So getting back to the important bit. I'm am sure wax you have done a fine job of building your truck but many don't think it is easy to build a 14mm ve pump for a td42, for flat out race use without having failures. That is a kick in the guts for some guys that have spent alot of hours at a bench for someone to buy it and pull it to bits to make their own.....
Are you implying i have pulled apart a race pump and built it calling it my own.
Nope. The main issue I had with your comment was only the fact you did not answer the mans question. Unless you are the guru he is lookin for and you will be supplying said device. Just saying its not hard, do it your self was a bit low. As you like to call it, it read like you were greater than tho.( The list of companies that were provide.) There has been alot of carnage from google builds. In the last two outings with Aaron, I have heard about 4 dead engines. And most of the conversations start with I was reading on the net and
And it seemed strange that when I asked about pump settings you got grumpy and assumed I built pumps. (I don't and never will) but I have a great respect for those that can..
So again if you have built a td42 that you can cane the arse off in the worst conditions and not have it die. You will have one hell of a smile on your face. With alot of people asking how you have done it.
Dumbass wrote:Nope. The main issue I had with your comment was only the fact you did not answer the mans question. Unless you are the guru he is lookin for and you will be supplying said device. Just saying its not hard, do it your self was a bit low. As you like to call it, it read like you were greater than tho.( The list of companies that were provide.) There has been alot of carnage from google builds. In the last two outings with Aaron, I have heard about 4 dead engines. And most of the conversations start with I was reading on the net and![]()
Thanks but as you know nothing about me you dont know if I am a google builder or not. The fact is its not hard and the only people who get really upset about the black art are the people who have been stiffing people for ages trying to make out its a black art.
Your on here making a big noise and then you say "I dont build and never will." FFS if you havent done one then dont comment!!!!! Now back to the kitchen with you
Awesome....... another potentially useful thread turns to shit
yup
Sorry guys I didnt mean to. Its not what I normally do.
I will stay out of this thread now i dont want to be known for ruining threads
Couldnt help myself
- Attachments
- 42913304.jpeg (72.69 KiB) Viewed 11208 times
027 MUD GEAR - (027 683 4327)
Check our facebook:
Batfastard
- Dr. Love Glove
Filthy4x4 wrote:Couldnt help myself
