Turbo Advice/Recommendation
Hi Guys, I have been building my truck for the last year and its pretty much done bar the f@#N Turbo!! I ordered one over 8 weeks ago and it is still supposedly coming but get told the same story every week and my pride and joy is just siting there not moving. Its a TD42T with injector pump mods- minor performance cam grind and a "SINCO" manifold. I need advice or recommendation where to go and who to speak to. I am after the ultimate turbo for a td42t. Please help
Re: Turbo Advice/Recommendation
turbo guru Steve Murch should have no problems with your request, he's in Auckland somewhere
Thanks mate, Any other recommendations?
I have fitted a few Master power turbos to td42's,
We stock them internal and external wastegated , cnc compressor wheels , water cooled , 1 year warantee , brazilian made and can do them for 1100 inc gst
Cool. could you tell me a bit more about it? when it starts spooling boost curve etc. Do you have a contact number/site?
pm sent
What pump mods?
GQTROL wrote:What pump mods?
Exactly and where do you want the power, is it auto or manual etc etc.
No such thing as the ultimate turbo as one persons opinion on how a motor performs is different to anothers. Absolute power or torque doesn't tell the full story as how it is delivered is as important if not more important that the peak figure.
Hey guys, Not sure exactly what the mods where but it was done by Tauranga diesel & turbo. i know its had the head head out of a Vx put in it and a full recon its flowing 25% ish more according to them. It's manuel with external gate. the truck is being built for off road/comp truck which will be riven on the road occasionally but i want the focus for off road, so lots of down low power which can cary through would be good.
I would encourage you to find out precisely what pump mods were done, as something seems a little amiss.
Standard GQ pump uses 10mm plunger and from memory runs 57cc's of fuel per 1000 shots. Most 12mm plunger upgrades should be in the 100+ cc's relm. I know nothing of Landcruisers (other than what is useful to bolt onto Nissans) so there possibly could be an 11mm plunger that was used in your pump, rather than the more commonly used 12mm?
You should be matching your turbo and pump to give you the result you want. Otherwise you could be a little disappointed with what you end up with.
Just looked at the receipt and this is what I found ---
Strip and inspect VE. Price to repair.
Rebuild & modify with parts listed,
Run up on test bench 20% more than STD turbo pump.
VE Pump Overhaul Kit
VE Zexel Aneroid Kit Only VE Roller Kit
VE 17mm Drive Shaft Seal VE Zexel Feed Pump
VE Plunger Shim
VE Plunger Washer
VE Flyweight Washer
Cross Piece
Spring
VE Shaft O'ring
Head & Rotor
Cam Plate
Spring
Freight & Handling Plungerspring Plate
Freight & Handling
Spring Set
VE Solenoid 24volt - EXTRA VE End Plug
HS Sealing Cap
VE K Dimension Shim
SHIM 1.00 Consumables
Bench Charge - Bosch 815 Electronic
I remember asking them what size it was and I'm pretty sure it was a 12 or possibly 13? I will find out on monday and re post.
Thanks for your posts guys its much appreciated
VE Plunger Shim
VE Plunger Washer
VE Flyweight Washer
Cross Piece
Spring
VE Shaft O'ring
Head & Rotor
Cam Plate
Spring
Freight & Handling
Spring Set
HS Sealing Cap
VE K Dimension Shim
Apologies, didn't realize it was a TD42-T pump that you had upgraded. In that case 20% increase over the standard turbo pump would be within the capacity of the factory turbo setup. So you ought to have plenty of scope for improvements with a turbo upgrade also.
Yes its a TD42-t pump. Hey does any one know how to down scale photos so I can post them up, I have literally hundreds of the build. I have a mac lap top and take photo with my I phone, completely illiterate with this stuff.
you need to upload them to an online media host of some sort (like photobucket.com) and once you have uploaded them you can re-size them on there, just hit the edit image button, choose re-size, type in the size and hit save. They even have the Img code beside each of you photos, so you just click on that, then come over to your thread and "paste" the link.
that might sound tricky, but just go step by step, it's easy enough.
Bring on the Pics!
Bring on the Pics!
i use http://www.picresize.com/ one site, follow the steps and 'save to disc' at the end. put it in a folder of resized images and you have them all in one place
Surf - 50mm lift, front bar, integrated winch etc
contactable on 0220901730
