GQ Td42 thermostat tee thread pitch for turbo coolant line
For all Nissan related topics
kcinshaw
Post by kcinshaw »
Hi there,
I am in the process of turboing my gq safari and I intend to tee of the heater coolant line at the theromstat. Does anyone know the thread pitch the tee needs to be to fit.
The return line I was thinking of using the 3/8BSPT plug at the rear of the block, I have heard mixed comments of this some saying its a return others saying its a feed. Can anyone confirm if it is a return.
I would like to avoid using tees in the heater hoses.
I have put an example picture of what I want to acheive below:
Nick
Re: GQ Td42 thermostat tee thread pitch for turbo coolant li
oh I tee'd in to the heater lines as closer to the turbo when I had water cooled one
mudtroll
Post by mudtroll »
Their is a oil feed by the engine mount, return best into the sump.
kcinshaw
Post by kcinshaw »
Thanks guys. I will use the engine mount oil feed and weld a return on the sump.
From what I can tell the thread for the thermostat housing is 1/4BSPT but i have not tried it yet. for the return i might need to use the heater hose
Trundle
Post by Trundle »
you can drill and tap a 1/4npt to dash 6an fitting where the factory water line goes and use braided lines
