As title says I'm after a 26 spline 5.12 ratio front diff or diff head urgently. Pm me if you've got one to sell
Need a 26 spline 5.12 ratio front diff or diff head
oneinkedgeek
Re: Need a 26 spline 5.12 ratio front diff or diff head
Could be tricky to find, you might need to get a 22 spline one and swap out the carrier or side gears from our broken one. Not sure if the vacuum disconnect ones will fit.
Did you break another one?
