Can you grease Y60 swivel hubs without disassembling?
Hey guys,
Coming from a 70 series Landcruiser where you are able to grease the swivel hubs by removing a bolt and filling with a grease gun. I can't see anything like this on my new-ish Y60 Safari?
Can it be done or does the whole thing need to be pulled apart?
Maybe remove a bolt and fill with grease or even retrofit a grease nipple?
1985 Toyota Landcruiser BJ73 with 13B-T
- mudlva
Re: Can you grease Y60 swivel hubs without disassembling?
Remove the wipers and apply grease then refit wipers again.
Imho Its a design cockup from nissan
If you are going to drill and tap then you will need to remove the complete hub
Remove one of the kingpin bolts - grease-gun fits nicely in the threaded hole. It takes a full tube of grease to fill the hub...
Awesome thanks guy, will sort out asap. Just another thing on the list giving the Safari a bit of a birthday (and cert).
- mudlva
muddy wrote:Remove one of the kingpin bolts - grease-gun fits nicely in the threaded hole. It takes a full tube of grease to fill the hub...
arhh this is why this site is so good
i knew there was an easier way then my my but hadnt worked that one out
pix or GTFO? I'm a complete mechanical noob and have no idea what a kingpin is. Cheers (from the computer nerd)
4 bolts holding a flat plate top & bottom of the swivel hub. The top ones include the steering ball-joints. I usually remove one of the bottom ones so any water can drain, although if your inner axle seal is leaking then be prepared for a fair bit of mushy mix of gear oil & grease to land on the driveway. The bottom ones are also easier to access without brake lines & steering joints in the way...
Ah yep that rings a bell (from the service manual I have) thanks.
Thanks for that
mudlva wrote:arhh this is why this site is so good
X2.
Thanks Muddy.
Get those bumps Slideways?
shortylux wrote:mudlva wrote:arhh this is why this site is so good
X2.
Thanks Muddy.
Yep got them last night
The king pin plates can easily be drilled an tapped for a small grease nipples
like this:
there are plastic seals under the king pins that i drilled 4 small holes in to let the excess grease into the swivel hub
like this:
Didn't barbie drive a jeep??
From memory if its never had the kingpin bearings replaced the above wont work.....they have a blanking plate from factory you have to remove these to replace outer bearing once gone then the above works
WARNING:
Yes that's what I was talking about, I put mine back in to keep the grease in the kingpin bearings but drilled 4 small holes in them to let some grease into the swivel hub
