Oct 28-29
Oct 28-29
didn´t do anything practical
but did some more research on my auto transmission found out they are relatively easy to adjust but you require a vacum gauge a vacum pump a pressure guage and banjo fittings to attach to the test point on the transmission
so i figure it will cost me just as much if not more to buy all the neccessary bits and pieces as it will to just take it to a mercedes specialist and get them to do it
so now i have to save my pennies got to find me a flatmate to make that a little easier
Lets see, Friday night, helped split trans from my 1KZ. Saturday took A340 & A343F trans' to be serviced and have bits swapped... then tried to get the 1KZ into my garage by hand... no chance... one hoist later all done. Nothing much else... mowed lawn, washed windows, went to Willowbank, all the normal keep the mrs & landlord happy type things...
Who knew Prados could fly?
nothing done on my truck.......
but checked out a few rentals and
might have sorted a place!!(always good
to have a place to live)haha
Yahoo.........
Yahoo.........
Took Lil Pig and a few other zuks out to a local farm today, dragged Callum out with me as well, assumed he enjoyed it
Couldnt let him go home without getting the cruiser muddy though. Promised him I wouldnt tell anyone that he got towed out by a tractor about 100m from where we started
Short day as pretty much all vehicles had one issue or another, but got muddy and had fun
lilpigzuk wrote:Took Lil Pig and a few other zuks out to a local farm today, dragged Callum out with me as well, assumed he enjoyed itCouldnt let him go home without getting the cruiser muddy though. Promised him I wouldnt tell anyone that he got towed out by a tractor about 100m from where we started
Get any pics?
Not much done today. Finished front supension yesterday, started on the rear as well, but decided id better finish cleaning the patrols interior (cant wait till the rovers going. I can just hose it
turoa wrote:lilpigzuk wrote:Took Lil Pig and a few other zuks out to a local farm today, dragged Callum out with me as well, assumed he enjoyed itCouldnt let him go home without getting the cruiser muddy though. Promised him I wouldnt tell anyone that he got towed out by a tractor about 100m from where we started
Get any pics?
dont think so, but may be a little bit of video footage floating round soon hopefully
callum007 wrote:all good.. cheers rex.. good day. reconfirmed the cruiser should stay in the garage.. maxxis creepies are for sale cos i think they are shit..
i looking for a zuzi to buy..
A) how much
B) You need beadlocks to get the best out of creepys. At 5psi they are farken awesome
C) what type of suzuki?
D) will the suzuki have a rover v8
E) what kind of drugs has rex given you? Just so I know to keep away from them
- billyvanboheman
As per my topic in the Mod's section I cut some holes in the Isuzu guard on Friday night for the snorkel.
SNORKEL PROJET LINK
Also was lucky enough to be lent a set of 33x12.5x15 tyres on cruiser rims to test on the Isuzu, looks real mean with them bolted on, now just a few rear spring changes to make and I will be able to fit a set of my own for weekend trips
SNORKEL PROJET LINK
Installed a new cylinder head on Dwaynes 1KZ in his surf. Took untill 2am Sunday morning untill we could start it up(with a break to milk the 270 cows). Today checked over what we had done the night before (beer goggles
) plumbed in a few rogue vacum hoses and filled up the cooling system and ran it up to temp in the shed.
Half an hour later off for a strop down the road and a play in the wet paddocks
Seems to be ok, nothing other than a couple of leaking fittings ontop of No. 3 and 4 injectors, so once those are sorted should do another 200,000+ k's
I don't ever want to do that job again
- mike
- Last minute Mike
Worked on the LR again this weekend. Wont bore you with the details except for today I planned to go into the garage about 9am and not come out till 5pm and get shit loads done, instead took old crusty out and went wakeboarding and got into the garage about 3pm and luckily enough the drive shaft off the 73 series 3 landy bolted straight up in the rear so I dont have to fabricate one up
Mike
Mike
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
1994 Toyota Surf
- Rotazuk
I have a bunch of programs here is use , but when quality is not an issue the easiest program I have found to use is windows movie maker . Not too bad and its free . I only use it for video to put on net etc .
Have not downloaded mine off the camera yet but will get onto it , and post some up .
Chris
Chris
wjw wrote:DieselBoy wrote:Installed a new cylinder head on Dwaynes 1KZ
It would be worth getting the radiator flow tested, all the diesel places recommend that after a 1KZ head has gone...
Yeah i told him that. He has had it re-cored recently, as he has had alot of drama with the radiator previously, causing it to overheat far to often and that repeated overheating will be what caused the head to go i expect.
I think the dent in his pocket will lead to a far more watchfull eye on temp gauge
I attempted to frankinstein two roofracks into one so that I could attach rod holders, spot light holders and luggage rack, ended up looking like I had a TV aerial on the roof
I made me a internal snokel after I had it ok'ed by the compliance guy. Not as straight out as I first thought, but at least it works and sounds friggin cool when I floor it
I was going to have a cool looking pod filter coming out of the dash but found I didn't have the room behind the dash I first thought. As well I might need compliance as it would likely be in my crash impact zone.
Benjamin Franklin
Benjamin Franklin
- mroffroader
[quote="Bubba"]I made me a internal snokel[quote]
so you ended up doing it!? did youn do it my way or sum other way?
Get any pics?
Short vid here doing what LP does best...... Rev
http://www.youtube.com/watch?v=y-dN1aK2ewg
thanks to rotazuk for the footage
;-p
well i diddnt do a lot.... pulled the rear diff out of BOSSHOGG with the intention of popping a lock right in it
.... exept it has an lsd in it !
... how am i sposed to fit a locker into an lsd carrier
so i pulled my front diff out of my 40 to put in the rear of the 80's, thout to myself "ill just check the state of the bearings etc before i put it in"...yea they are shagged
DAMMIT !.... so now i have to find a diff in good condition that i can install a locker in and fit to the 80's
and then i went for a quick ride on sunday,just enough to remind me that my bike really is mad fun
so to sum up, 2 cruisers in pieces and a dirty bike
ohh and i got a bug,chest infection and sore throat,sneezes etc..... dumb bugs
- mroffroader
lilpigzuk wrote:turoa wrote:lilpigzuk wrote:Took Lil Pig and a few other zuks out to a local farm today, dragged Callum out with me as well, assumed he enjoyed itCouldnt let him go home without getting the cruiser muddy though. Promised him I wouldnt tell anyone that he got towed out by a tractor about 100m from where we started
Get any pics?
hahaha mint vid man
- billyvanboheman
Bubba wrote:I attempted to frankinstein two roofracks into one so that I could attach rod holders, spot light holders and luggage rack, ended up looking like I had a TV aerial on the roof![]()
BWAHAHAHAHAHA, hope you got some photos of that, could become a very sought after accessory.
[/quote]
Made a Mark 2 version of it, looks much cooler now.
Many thanks to the Wellington Tow Bar Services for all their assistance
Benjamin Franklin
Benjamin Franklin
working on some more vids but this is a start
http://www.youtube.com/v/mPREG1FCaGE
callum007 wrote:working on some more vids but this is a start
bwahahaha, forgot about the gorse whips
http://www.youtube.com/watch?v=6my8mQs1qH8
http://www.youtube.com/watch?v=ZvoWhWDGnOQ
http://www.youtube.com/watch?v=NgfpRWkCedw
- PuddleJumper
