cam regrind ?
Posted: Tue Nov 19, 2013 8:01 am
I'm looking to take my spare ld28 cam in for a regrind to suit running a turbo a little more and to move the torque curve towards the low end.
the ld28 we run in the bush truck absolutely hisses at 4500-5300 but doesn't really do much till then.
I'm guessing its a combination of a camshaft profile more suited to a road car with no turbo along with possibly the pump timing being a little out.
Now tell me if I'm correct in my reasoning if we can get more duration on the cam it will induce a little more air which should help with the spool up,
along with a little more lift to make the airs path a little easier.
Not forgetting that more air means we run more fuel to keep the engine from leaning out and making piss all power.
Anyone delved into this with something to add?
