1989 NZ new doublecab Hilux dereg
Custom steel flatdeck with rollbars and locking alloy toolbox
Modified generic steel bullbars with winch mount and brush bars (winch not included)
4Y+E with 5spd manual (4Y (2.2L petrol) retrofitted with EFI setup from YN130 surf), otherwise standard drivetrain, new inner axle seals, pinion seals need doing have a front one around somewhere.
Has front bucket seats from some old subaru maybe a leone.
Average condition inside an out considering its use but not too bad really. Not as much rust as you would imagine. The usual wear in the drivers side floorpan and holes forming in the back of the cab at rear wheel arch area, other than that nothing significant (inside the doors etc has been sprayed with waxoyl or some other greasy rustproofer at some stage)
Only selling as its just not getting used enough as its a fraction too heavy for the Terrano to tow around
