what does an Auto on a d21 terreno do that shows its stuffed
what do these Autos do that tells you the trans is stuffed what are the things to look for that can tell you your in for a big bill
Re: what does an Auto on a d21 terreno do that shows its stu
philip121 wrote:what do these Autos do that tells you the trans is stuffed what are the things to look for that can tell you your in for a big bill
It will float in and out of over drive the oil will be a manuka honey colour.
Line pressure solenoid if worn will make for jerky gear changes. or very slow gear changes...depends on if its stiff or flogged out.
Torque converter may not lock up properly
usual signs
Probably the same thing any auto does..
Trans fluid smells burnt.
Slow to change into gear from N.
No gears at all.
Wont go into OD.
Wont drop out of OD when you press the button.
Clunky gear changes. Or very long ones.
Wont kick down.
Noisy.
Worse fuel economy than usual.
No gears at all.
Wont go into OD.
Wont kick down.
Noisy.
[ see that this is an important issue
regards if owners have a failing AUTO
- Attachments
- 0dxaWWgQZ.gif (67.82 KiB) Viewed 1716 times
CLUMZ1 wrote:Do Not Feed The Trolls
Unfortunately this thread was going quite nicely until you 'fed the troll'
Maybe if you would edit your post to something more constructive, then philip121 would in return edit his to remove the garbage from a potentially good thread?
Only posting this as phil has had a hard time on here, left for a bit and now has returned bringing improved his grammar and spelling, hopefully suggesting also an improvement of attitude??
You quoted me so I've decided to keep the post. By the way his spelling & grammar are still ####### awful and I'm still convinced its a trolling account.
I'm actually impressed with your reply. Too often on here people take things way to personally, and threads get wrecked with toy throwing...
Yes I agree, he has a lot more to improve with grammar etc.
Not unconvinced myself either, was just hoping for the best.
I can edit my posts away also if liked, to leave this thread on topic?
only problem still remains on this forum theres young lads running people down
I see this what does an Auto do that shows its stuffed as a valid subject
and its all over because of a child
when is this dump getting its members sorted
maybe when more leave
