feroza gearbox advice needed!
- greenferoza
- Stropper
Hi all ive had my feroza for nearly a year now ive taken it out a few times but it struggles abit being fulltime 4wd and not having high low ratio. Whats needed for me to change to a high low ratio transfercase setup. Any help will be appreciated cheers!
Re: feroza gearbox advice needed!
Firstly the transfer case or complete gearbox to bolt up (possibly driveshafts too but ild assume full time and part time have same lengths) and then cut a whole in your floor for the transfer case lever as its probably not there, that should be about it
Is it auto or manual by the way as im assuming manual for the above info but auto should be mostly the same stuff.
Ferozas are pretty simple old machines so not much can go wrong, have a rebuilt engine for one sitting in my garage if you ever need one
gigidy gigidy gigidy goo
- greenferoza
- Stropper
Cheers for help mate its a manual and it already has a hole for my centre diff lock / fulltime 4wd lever so hopefully its the same. I need to do a clutch change so once i find whats needed ill do it all while its out.
