LN100 steering arm hits Ubolts
brakes-shocks-lockers-etc
mudbugga
Post by mudbugga »
Mate has a LN100 Hilux that is a work in progress.
He has fitted a 4wdbits EFS 75mm suspension kit in it and the steering arm is hitting the Ubolts on the drivers side. Even does it on level ground.
Is there a simple solution to stop this, or does he have to go to a hi-steer kit?
Smurf
Re: LN100 steering arm hits Ubolts
Post by Smurf »
Are you still using the factory round u bolts?
If it is only just hitting, then a flat top u bolt may give enough clearance
http://www.4wdbits.co.nz/ProductDetails ... ductID=346
mudbugga
Post by mudbugga »
He's already got the ubolts with the flattened tops fitted. They were in the kit he got.
I suspect it will need either the drop drag link
http://www.4wdbits.co.nz/ProductDetails ... ductID=707
or the hi-steer kit.
http://www.4wdbits.co.nz/ProductDetails ... uctID=4679
Anyone had any experience with either of those?
madlux
Post by madlux »
Yes, I had that problem, got same springs. Only solution I found to fix it was high steer kit
