Page 1 of 3
another overheating terrano
Posted: Fri Nov 29, 2013 7:49 pm
by BDR3M
This is really getting to me! all info to sort this outfound here and still no luck help! 90 model import terrano
new radiator
new water pump
new hoses
new coolant
even had the viscous clutch off to day and inspected the oil/silicone all good
now it only gets hot when air con is on or uphills dont have the aircon up hills or the temp gage hits 120 degrees way to quick, so im left with either i need another fan on tje condencer or a head check am i on the right track? the previous owner is positive if i make up/find some of those engine bay guards in the wheel well to the chassis those things it will stop the problem...really? any help would be great!
cheers guys.
Re: another overheating terrano
Posted: Fri Nov 29, 2013 7:59 pm
by Crash bandicoot
BDR3M wrote:This is really getting to me! all info to sort this outfound here and still no luck help! 90 model import terrano
new radiator
new water pump
new hoses
new coolant
cheers guys.
Do a leak down test and a water jacket pressure test. Do you still have the shroud around the fan?
Posted: Fri Nov 29, 2013 8:18 pm
by philip121
hope with all those parts you got a new thermostat
Posted: Fri Nov 29, 2013 8:50 pm
by BDR3M
was in a rush before nagging girl friend, has shroud pressure tested rad,thermostat is new also has transcooler im at wits end. 10years as a mechanic and this is stumped me :(
Posted: Fri Nov 29, 2013 8:54 pm
by philip121
when it gets hot do you stop and see if it is
it may be reading hot when not does it boil
Posted: Fri Nov 29, 2013 8:56 pm
by BDR3M
has after market temp gauge installed and boiled it last saturday and blew up the top hose so shes boiling alright
Posted: Fri Nov 29, 2013 8:59 pm
by philip121
well it may be head gasket or cracked head
Posted: Fri Nov 29, 2013 9:12 pm
by slide
BDR3M wrote: 10years as a mechanic and this is stumped me :(
Don't let it get ya :twisted:
Go back to basics.
Water circulating?
Water shedding heat through radiator?
Airflow over radiator?
Gauge accurate?
Check temp of water going into engine, not only going out of engine.
Test components-don't just replace things and hope its going to fix it. How do you know the replacment part isn't faulty? (new is no guarantee)
You'll find the problem if you take the time to check everything over. Surely 10 years as a mechanic you'll have some workmates who can help ya out?
You'll get it if you work over every thing rythmatically (is that a word??)
Posted: Fri Nov 29, 2013 9:26 pm
by BDR3M
dealership mechanic so some things are new to me (one of them toyota boys) itsvlike the thing just cant deal with the climate in QLD
Posted: Sat Nov 30, 2013 7:16 am
by klompy
What size tyres are you running.
Posted: Sat Nov 30, 2013 11:19 am
by BDR3M
235/75r15 not sure what that is in metruc 28-29inch :s i have a set of 31x10.5 15 i wont to put on.
Posted: Sat Nov 30, 2013 12:06 pm
by philip121
did you replace radiator because of cooling problems or just to upgrade truck and now there problems
pressure tests would show up heads or block or head gasket I think
long shot is the radiator working or the correct size.
Posted: Sat Nov 30, 2013 12:33 pm
by kbushnz
BDR3M wrote:only gets hot when air con is on or uphills dont have the aircon up hills or the temp gage hits 120 degrees way to quick,
Ok so it only does it as above...
My gut feeling is telling me there is not enough air coming thru ...to remove the heat from the radiator.
And the viscous fan is faulty... Just cause its full of silicone doesn't mean its working...
There is a bimetallic spring coil on it which moves the valve around when its hot and changes the amount of fluid it bypasses...
If its broken or jammed up then it may not couple the fan properly...
Normally it will roar rather loud when it kicks in...
My 10 cents worth....
Posted: Sat Nov 30, 2013 12:55 pm
by kiwipete
Yep, my money is on the fan too.
I would also check the aircon radiator is not fouled with bugs and other shit as it sits in front of the engine radiator and could be obstructing airflow.
As for radiator shrouds, mine has the bottom section removed since I did the body lift and I have no issues with over heating; well not any more 8)
I know of some who have removed theirs all together and have no issues either. When the fan is working as it should it sucks a power of air.
edit; There is the possibility that you may have an airlock in the block somewhere too?
Posted: Sat Nov 30, 2013 1:43 pm
by BDR3M
after a bit of playing around this morning im looking at the fan again on start up its not "roaring" bit annoying as its had 2 water pumps in the last 2 years previous owner said so rad/condencer/transcooler are all clear of muck. will source another pump and fit a extra fan to condencer.
i didnt fit new parts was done before i bought it but had all receits dated no more than 6 months ago.
Posted: Sat Nov 30, 2013 1:50 pm
by kbushnz
Fan wont "roar" until it starts to get hot enough to activate the hub and make the fan do some work...
Mine only does it when air cond on for a while or some serious throttle work...
You can feel the engine load up when it kicks in....
Posted: Sat Nov 30, 2013 2:54 pm
by BDR3M
right on start up they engage for maybe 15-20 seconds or is this something iv just noticed on toyotas?
Posted: Sat Nov 30, 2013 2:55 pm
by kbushnz
BDR3M wrote:right on start up they engage for maybe 15-20 seconds or is this something iv just noticed on toyotas?
Mine doesn't lol.. and its a Toyota !
Perhaps mine is on the way out also !
Posted: Sat Nov 30, 2013 3:06 pm
by Smurf
they can engage at start up as the fluid in the hub all drains to the bottom of the hub and when you start the engine the fluid locks the hub for a few seconds until it is pumped out of the hub back into the reservoir.
Posted: Sat Nov 30, 2013 3:17 pm
by kiwipete
BDR3M wrote: will source another pump and fit a extra fan to condencer.
Erm, could you not just buy a new hub without having to replace the whole pump?
Posted: Sat Nov 30, 2013 4:32 pm
by tweake
i would be inclined to check what radiator was fitted. seen the odd case of new radiator being worse then a 2nd hand factory one.
Posted: Sat Nov 30, 2013 4:46 pm
by BDR3M
nissan thought it would be a great idea to make it one peice its a TD27
Posted: Sat Nov 30, 2013 7:22 pm
by crazyclark31
does the truck smoke much? High egts will make it heat up pretty quick.
Also check to make sure it actually has a thermostat in it because if it doesn't the water can travel too fast through the radiator and it wont cool down enough before it leaves the radiator
Posted: Sat Nov 30, 2013 7:31 pm
by travis2ninja
I think it's just TD27Ts in Terrano.
Posted: Sat Nov 30, 2013 7:54 pm
by BDR3M
crazyclark31 wrote:does the truck smoke much? High egts will make it heat up pretty quick.
it smokes very little even with my foot on the floor yea thermostat is in when i put the new hoses on.
Posted: Sat Nov 30, 2013 9:43 pm
by tweake
crazyclark31 wrote: Also check to make sure it actually has a thermostat in it because if it doesn't the water can travel too fast through the radiator and it wont cool down enough before it leaves the radiator
not true.
reason no thermostat makes it run hot is the bypass port is left open. it needs the thermostat to block it. that means a sizable % of water simply bypasses the radiator through the bypass and doesn't get cooled.
Posted: Sat Nov 30, 2013 10:02 pm
by philip121
new parts fitting only works if you replace every part of ALL the TRUCK
I bet I hope but it seems to me theres a miss match here and not a total loss
Posted: Sun Dec 01, 2013 10:30 am
by BDR3M
if i took some photos could some of you be able to tell if the parts are a miss match?
Posted: Sun Dec 01, 2013 10:44 am
by kiwipete
Post them up on here. :wink:
Posted: Sun Dec 01, 2013 11:25 am
by BDR3M
see if this helps?
