Howdy Guys
Im After a set of shocks for back of my wagon.
Had some from an 80 series (I think?) running upside down,
but they're well poked.
And the standard ones wont even reach on the flat.
Its got 4 inchs of lift in it. Eye on top, stud down the bottom.
Im after something with these lengths Approx if you know of any.
Min length: 350mm
Max length: 650mm
Have searched and looked around,
Called shops and been to shops but everything is vehicle matched and nothing is made for these wagons with that much lift.
Any help much appreciated.
Also, anyone know what mods are actually needed to fit these?
http://www.4wdbits.co.nz/ProductDetails ... ductID=273
Cheers, Micah.
Rear shocks for KZJ78 Prado
Re: Rear shocks for KZJ78 Prado
i put long ones in the front and back of my 71 ,will see if there is still a part no on them
Cheers, that'd be brilliant.
micahb wrote:Also, anyone know what mods are actually needed to fit these?
Yes they work... But you need to do some trimming to the chassis and other stuff to make them fit....
And then require cert.....
Phil Clark has done it to his Playdoh....(https://www.facebook.com/Force4wd?ref=profile)
Range Rover shocks for the 95 to 02 years have the same pin / eye combo for the Prado... Might just need to change the bushing at the top...
I have used Toughdog ones... But its hard finding them at 650mm... Can get close to 630 ish..
I have been naughty and have some EFS shocks from the front of a lifted Patrol.. And swapped the eyes over...
kbushnz wrote:micahb wrote:Also, anyone know what mods are actually needed to fit these?
When you say, swapped the eyes over, do you mean cutting off one and welding on another to the shock?
Cheers for the info.
- TerrainTamerNZ
- Driver/Navigator
We have a Terrain Tamer set, Twin Tube Expanded Body Gas. Pin bottom, eye top. Open/Closed 654-397. Close to what your looking for. Give us a call if you have any questions =).
Regards,
Regards,
- DizzySwinger
- Winch master
Hi Micah
What did you end up doing. Im looking at doing the same but only a 3" lift. would you have any ( Cost effective ) suggestions my friend.
Cheers Dizzy
Cheers Dizzy
I just got a pair of Ranchos for my project in from Summit Racing in the US after failing to find the right size etc locally. Delivered cost was a smidge cheaper then buying them here.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
