F/S Vitara rear disc mounts
Posted: Wed Dec 04, 2013 9:48 am
by Rotazuk
Any interest in the mounts I made to mount Misti calipers onto a vitara rear diff ? I can throw in the calipers but they will probably need new pads and I have to find one of the handbrake cable mounts . Not sure if you use them to get the cable working , never hooked it up . They are made out of 10mm plate and are spaced for 413 ( think non vented vitara are the same ) mounted over cut down drum housings .
The calipers sit at the rear , they should clear all the susp stuff on a std vitara but I have never had them on a std diff .
Chris
