Toyota Surf 2.4lte RED LIGHT HELL!
Camfitz30
Post by Camfitz30 »
I pulled the error codes out of my truck (8 and 24) which is air intake temp sensor.
I put the ohms meter accros it to see what the resistance was doing and it was workingas it went from room temp to in my hand! (but im not sure what the range is?)
Whats next? WIring Loom? ECU?
does anyone have a wrecked one of these i can try parts out of?
Im located it timaru
______________________________________________________
8 24
INTAKE AIR TEMPERATURE SENSOR SIGNAL--OPEN OR SHORT IN INTAKE AIR TEMP. SIGNAL
--INTAKE AIR TEMPERATURE CIRCUIT
--INTAKE AIR TEMPERATURE SENSOR
--ECU
slide
Re: Toyota Surf 2.4lte RED LIGHT HELL!
Post by slide »
If they're the same as 2l-te from prado (lj71) I have an ecu and air temp sensor. Pm me if keen
