Hi Guys,
I failed a wof on both bottom ball joints, and went to repco and got some new ones, and the guy over the counter said there is a trick to getting these out, i have had a look and it seems straight forward but before i start this i was wondering if there are indeed any tricks to getting these out?
Thanks
kzn130 bottom ball joints removal "trick"
Re: kzn130 bottom ball joints removal "trick"
The shaft of the ball joint is a tapered fit and can be a bit of a mission, usually a good tap with a hammer to the side pops it out.
truckingood
- Bush Crasher
BFH, that's the best trick
Use one of the chisel type ball joint splitters and a good solid whack with a BFH. Only had one that wouldn't pop out so had to get some heat involved.
Toyhatsu Bitsalux
- catalystracing
Just had a real %*&^* of one to get out a few weeks back which needed a porter power between A arms and a BFH
Sometimes winding the torsion bar down helps take a load off also.
Usually the advice previously mentioned is enough
stealth wrote: but before i start this i was wondering if there are indeed any tricks to getting these out?
Thanks
Yep
thanks all!
