after I fiddled with all the sensors, everything vacuum in the ADD system is working as well, even the 4WD actuator motor on the T-case is working perfect when connected direct to a 12V source it seems the 4WD ECU is buggered. measured with a Volt Meter every value on the ECU connector is spot on except 2 and 3 or M1 and M2, there is nothing coming out.
Toyota part # 89533-35021
Where do I get a 2nd hand 4WD ECU for cheap ? tried TradeMe, nothing. who knows a good place which would ship NZ wide. I live in Naseby, that is way off the grid so I rely on mail orders.
cheers,
steve w.
KZN130 Computer 4WD Control (ECU) AISIN
Re: KZN130 Computer 4WD Control (ECU) AISIN
Whats Your Offer?
Cheers Leigh
Cheers Leigh
thanks Leigh, it's sorted, got one for $245
cheers,
steve
cheers,
steve
