I have a 1990 Prado lj78
the 2.4lt bottom end went so I replaced it with a rebuilt 3l . with a mechanical
injector pump .
Now I have no tech and my transmission shifts at high revs
I found I can control the shift with The Rail II shift controller
but hav not a clue where to start on repairing my tec
need help on rewiring my tech
Re: need help on rewiring my tech
So you had a 2LTE ? ...
The tacho signal in the 2LTE is generated in the fuel pump and sent to the ECU to control fuel as well as shift points then feed out to the tacho.
The 3L sender unit is different and sends different signals...
So I doubt you can use the same signal without converting it...
Most people manualise the auto.... Or you can use an after market controller. Which are normally big dollars.
Have a read thru this thread http://www.offroadexpress.co.nz/Forums/ ... 17&t=29063
Also welcome aboard and use the search feature....
I used a Jeep Cherokee Trans controller for my 2J Prado, worked great
Who knew Prados could fly?
wjw wrote:I used a Jeep Cherokee Trans controller for my 2J Prado, worked great
do you have a model number and or vehicle that it came from as Im looking at trying to track one down for club runs as a full auto.. then switch to manual auto for events..
I can't remember, Same as Rick Crosbies, Offroad Racing Cherokee...
I've texted him, he'll know
