Playdoh exocage main hoop and rear tray concept
All aspects of safety with 4wds from proper mounting of tow hooks to recovery situations.
kbushnz
Post by kbushnz »
Ok Boys and girls...
Cast yah eye over this and see if there are any issues....
High level concept....
Aim is for it to comply with ORANZ rules... for winch challenges..
Tube work is either roll cage tube or that 32 nb steam pipe stuff...(green and purple)
The red is the main tray and I want it strong enough to mount the cage on...It will be 3mm wall thickness...
Just toying with either 40x40 or 40x75 box. (or combo)
Would like something like 40x60 but its not made in that size...(that I can find)
The main hoops will be welded directly to the box....Cross braces will pass thru the box and be welded also...
The box sections will be bolted to the chassis as per ORANZ with plates etc etc..
Want to keep it simple but strong...
Batfastard
Dr. Love Glove
Re: Playdoh exocage main hoop and rear tray concept
Post by Batfastard »
No b pillar ,glen has a b pillar that he welds in for oranz events ie t1000 then cuts it out for safari stuff so rear door can open ... The back stays look like they are at too much off an angel i would lower them down the main hoop . May be 250 300 mm .but realy cant see how you will get oranz to like the no b pillar.dont think im that keen to roll over in that exo .at 50 kph let aloan 140 plus kph that your truck is able to do .
kbushnz
Post by kbushnz »
yeah I was going to make up a removable B pillar one.. For hard yakka trips and winch challenges..Also tie it back along the middle of the rear door....to the main hoop...
Don't want to run in ORANZ events... just use the concepts for the cage...
Their rules seem easier to follow / understand....lol
Scale in the photo's is a bit off....So side view is a little deceptive...
Keep the comments coming.... :mrgreen:
chrome
Post by chrome »
65x35 rhs is readily available, makes a nice lookin deck, strong but not too heavy
DIRTY OLD HILUX
022 519 7700
shortylux
Post by shortylux »
My advice would be don't use the MANZ tube for an exo. Being only 2.6mm wall it might bend to easily when banged on trees etc. The Steam pipe is 3.8mm wall from memory. Also you will need a much more expensive bender to bend MANZ tube (my $400 bender does the steam pipe perfect but ripples the MANZ tube)
Bear in mind that exo's tend to be anchors. My b pillar dents were as a result of the exo grabbing a tree and sucking me on to it. So think carefully about body/cage clearances and out riggers etc etc.
My understanding of the (ORANZ) rules is that the roll cage must be mounted to something of an equal or greater thickness. Ie you would have to use 4mm wall RHS for your tray if you are going to use the 3.8mm wall steam pipe.
ORANZ do specify maximum spans so make sure you don't go out side these.
You rear brace angle looks okay to me, but do your measurements. From memory minimum angle is 30 degrees.
Trundle
Post by Trundle »
32 nominal bore black pipe comes in 4mm wall thickness from memory ,
Batfastard
Dr. Love Glove
Trundle wrote:32 nominal bore black pipe comes in 4mm wall thickness from memory ,
Thats what we used on my truck .it was sweet with our roll at t1000 not much damage atall :D
Trundle
Post by Trundle »
seems to plow trees fine , i did use the 44mm cage steel but its to thin
big-b
Post by big-b »
Hi there, bit off subject but who cut down your truck? I want to do my safari and am capable of cutting it and building the tray etc but unsure about how to put in the rear wall. I'm located in Auckland if you know any one capable of doing it? Any info would be much appreciated cheers
kbushnz
Post by kbushnz »
big-b wrote:Hi there, bit off subject but who cut down your truck? I want to do my safari and am capable of cutting it and building the tray etc but unsure about how to put in the rear wall. I'm located in Auckland if you know any one capable of doing it? Any info would be much appreciated cheers
I did it myself....
Read http://forum.ih8mud.com/threads/prado-o ... st-8691691
Jafa
Post by Jafa »
x2 on NOT using MANZ cage tubing for an exo, I did, and it bends and dents like toilet roll tube :roll: lol
Use something with descent wall thickness... unless you're going for light weight, in which case use chromoly :lol:
2c
021 273 9942
jafa@inspire.net.nz
Return to “4wd Safety”
