80 series fuel tank.
Posted: Sat Dec 28, 2013 12:30 pm
by firestonecruiser
out of curiosity shud the fuel tank on a 80 series pressurise. i have noticed lately when u remove fuel cap a burst of air is released. i have a metal fuel cap and on the neck of the filler there is a breather hole. if it shuoldnt pressurise is it just a case of removing breather hose of tank and giving it a blast through with air.
cheers jono
Re: 80 series fuel tank.
Posted: Sat Dec 28, 2013 2:56 pm
by mudlva
Yep breather is blocked guessing pressure is coming from fuel heating up as it should be under vacuum as the fuel is being used.
Either way the hose is still blocked
Posted: Sat Dec 28, 2013 3:51 pm
by firestonecruiser
had a look under it and found a hose with a filter type thingy on it that went toward fuel tank, other end is poked into the chassis so pull it out and nothing on the end. any one got a diagram of wat this is.
cheers jono
Posted: Sat Dec 28, 2013 5:48 pm
by firestonecruiser
done more research and apparently fuel tank should have slight pressure. oem fuel caps have a one way valve in them to let in some air as fuel levels decrease. the hose i found under neath is a breather with again a 1 way valve to release the extra pressure. am going to try and remove this valve as no doubt it will be full of crap and run it up along side filler and overflow neck with a fuel inline fuel filter attached and end of hose will sit along side fuel cap. does anyone have a genuine 80 series fuel cap.
cheers jono
Posted: Sat Dec 28, 2013 6:19 pm
by Ashohman
let me know what you find out mine does this too. wonder if its why my fuel pump seems to wine after a while.
Posted: Sat Dec 28, 2013 7:13 pm
by firestonecruiser
Ashohman wrote:let me know what you find out mine does this too. wonder if its why my fuel pump seems to wine after a while.
does yours have a genuine fuel cap with the valve
Posted: Sat Dec 28, 2013 7:48 pm
by Ashohman
mines petrol with a diesel
cap no valve that I can see. but yeh ive wondered about that breather from the tank that goes to the frame rail
Posted: Sat Dec 28, 2013 8:00 pm
by firestonecruiser
will have to try track down a genuine cap or just drill a 2mm hole in cap i got.
cheers jono
Posted: Thu Jan 02, 2014 4:31 pm
by firestonecruiser
firstly couldnt get a fuel cap. the repco had listed for 80 series didnt fit. so drilled a 2mm hole in existing cap. removed the tank breather and sure enough valve was blocked, cleaned it all out replaced hoses and run it up to fuel cap. first impressions it seems to respond a bit better to jandal and run a bit smoother. had only just finished the job and took for a run and got a bloody speeding ticket. was a great start to the new year.
cheers jono
