WTD 70 series drive flanges
Weeds
Post by Weeds »
Hey guys any one got a set of drive flanges to replace Manual hubs for sale
mudlva
Re: WTD 70 series drive flanges
Post by mudlva »
why do you want to remove the manuel hubs for?
the OE aisen hubs should't be failing
Weeds
Post by Weeds »
The hub split in three pices cv snapped clean in half again.Powerd by 350 chev think this is the problem. Going to look for chromoly cvs and do away with the manual hubs just want a reliably strong set up.
suzolla
Post by suzolla »
Hi,
Surprised an Aisin hub split, you sure it wasn't some other brand.
If you are going to use Longfield axles and CV's and want to maintain the Longfield warranty you will need to use Longfield drive flanges.
Can help with both, PM me if interested have a look at http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=64&t=32760
Tim
tallsam66
Post by tallsam66 »
You can now buy Aisin look alikes ...they aren't as good as the real Aisin.
Weeds
Post by Weeds »
Do I have to run long field axels with there cvs ? I was planing on runing std axels with new cvs for time been
suzolla
Post by suzolla »
Can use 27 spline longfield CV's which will make your axles the weak link.
If you are breaking genuine Aisin FWH's have a 350 Chev and drive reasonably hard then you would probably be better off with the 30 spline supersets.
If you want to go 27 spline longfields have got some as well.
Or other option is Trailgear CrMo better than stock CV's, have some of these as well.
Tim
mudlva
Post by mudlva »
?welded diff by any chance??
Weeds
Post by Weeds »
No wElds all open
oldblue
Post by oldblue »
Got a set of 27 spline long flange ( early 27 spline ) can be machined to short length.
and a set of 27 spline short flange ( later, 70 series ) end caps are a we bit loose.
sig
Jeep Jeep
Post by sig »
i,m in nelson this week gareth if you want me to pickup :D
Weeds
Post by Weeds »
Thanks for the offer sig but I think you have done enough to help me out this week. Do u know if the flange I borrowed of you was a short or long flange ?
Enjoy your holiday
sig
Jeep Jeep
Post by sig »
not sure what mine was .if you want a set i will grab the other set .machining is no problem
