WTD 70 series drive flanges
Posted: Sun Dec 29, 2013 9:16 am
by Weeds
Hey guys any one got a set of drive flanges to replace Manual hubs for sale
Re: WTD 70 series drive flanges
Posted: Sun Dec 29, 2013 11:43 am
by mudlva
why do you want to remove the manuel hubs for?
the OE aisen hubs should't be failing
Posted: Sun Dec 29, 2013 12:10 pm
by Weeds
The hub split in three pices cv snapped clean in half again.Powerd by 350 chev think this is the problem. Going to look for chromoly cvs and do away with the manual hubs just want a reliably strong set up.
Posted: Sun Dec 29, 2013 12:37 pm
by suzolla
Hi,
Surprised an Aisin hub split, you sure it wasn't some other brand.
If you are going to use Longfield axles and CV's and want to maintain the Longfield warranty you will need to use Longfield drive flanges.
Can help with both, PM me if interested have a look at
http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=64&t=32760Cheers
Tim
Posted: Sun Dec 29, 2013 3:34 pm
by tallsam66
You can now buy Aisin look alikes ...they aren't as good as the real Aisin.
Posted: Sun Dec 29, 2013 4:27 pm
by Weeds
Do I have to run long field axels with there cvs ? I was planing on runing std axels with new cvs for time been
Posted: Sun Dec 29, 2013 6:13 pm
by suzolla
Can use 27 spline longfield CV's which will make your axles the weak link.
If you are breaking genuine Aisin FWH's have a 350 Chev and drive reasonably hard then you would probably be better off with the 30 spline supersets.
If you want to go 27 spline longfields have got some as well.
Or other option is Trailgear CrMo better than stock CV's, have some of these as well.
Tim
Posted: Sun Dec 29, 2013 6:22 pm
by mudlva
?welded diff by any chance??
Posted: Sun Dec 29, 2013 7:16 pm
by Weeds
No wElds all open
Posted: Sun Dec 29, 2013 7:28 pm
by oldblue
Got a set of 27 spline long flange ( early 27 spline ) can be machined to short length.
and a set of 27 spline short flange ( later, 70 series ) end caps are a we bit loose.
Posted: Sun Dec 29, 2013 7:49 pm
by sig
i,m in nelson this week gareth if you want me to pickup
Posted: Mon Dec 30, 2013 3:49 pm
by Weeds
Thanks for the offer sig but I think you have done enough to help me out this week. Do u know if the flange I borrowed of you was a short or long flange ?
Enjoy your holiday
Posted: Tue Dec 31, 2013 8:26 am
by sig
not sure what mine was .if you want a set i will grab the other set .machining is no problem
