TD42 wanted
TD42 wanted
Anyone have or know where there is a TD42 motor for sale ,mine just went bang,heaps of blow by now,and sounds like theres a little man inside with a f#cking big hammer ,still runs but idels real rough and sound horrible ,pm if you have one or know of one .cheers
Re: TD42 wanted
Where are you? I've got one with a cracked head but no known problems lower down. Has done around 300,000 km. In Blenheim..
Re: TD42 wanted
hi cheers im in Auck so frieght would kill it ,,I just found a runner for $500 exchange ,am going to grab it ..Steve
Re: TD42 wanted
Just did a compresson test
1=400
2=395
3=400
4=400
5=0
6=390
so something has let go in no5 ,it has valve clearance and rockers are moving .BUGGER
1=400
2=395
3=400
4=400
5=0
6=390
Re: TD42 wanted
drop the sump off and see if its the rod or bits fall out.. might be fixable I would think.. if it a rod..
Re: TD42 wanted
What on the exchange or the bang one?
Re: TD42 wanted
the compression test was the old motor
Re: TD42 wanted
Found the problem ,no5 liner is in a million bits in the sump
first time i have seen or heard of this ...
Re: TD42 wanted
wow the piston seize, then beat the crap out of the liner, or liner cracked then failed,with piston movement
