can anyone tell me how to back off hilux rear drums? I was trying to get the handbrake going for pre cert wof tomorrow flicked the wee clickers around on both sides but have over done it on one side and it doesnt go backwards like 4wheeler ones do, any advise be great as I doubt ill get the drum off now.
Thanks Stu
Help rear brake adjustment
- mudlva
Re: Help rear brake adjustment
Try releasing the handbrake tensioner on the cable and see if that will give you enough to turn the wheel otherwise a small flat screwdriver to hold the non'reverse lever out to unwind the adjuster in the drum
Good luck patience will be your virtue here i think
Awesome thankyou got sorted had to hold my fone in my mouth with the led torch bit pointing into hole to see what to do I think next time Ill mess with it during the day
Thanks Stu
Thanks Stu
