Nissan TD27 Fuel Pump adjustment- question
A place where Useful information on makes of 4wd is stored by Tech Authors.
Moderators: Steve_t647, Tech Authors
blorigan
Post by blorigan »
I had an issue with my mistral fluctuating revs in top gear by around 200rpm ( whil travelling 100kph)
I have since adjusted the electronic component on top of the geared fuel pump by rotating it ant-clock wise by approx 3mm and the problem has gone. does anyone know the full fucntion of this electronic controller and how much it can be moved etc
thanks
slide
Re: Nissan TD27 Fuel Pump adjustment- question
Post by slide »
That's the TPS (throttle position sensor).
Usually set to 0.5 volt output at idle from memory.
Adjusting it can hide other problems, or it may have been set wrong.
blorigan
Post by blorigan »
thanks
with the new motor fitted, im thinking ( hoping) it was just slightly out due to teh motor/ fuel pump diferences
Return to “Tech Section/Library”
