Unfortunatly due to health and just plain bad luck and NZ's shitty econonics,I have to sell my CJ3 Jeep
Powered by 350 SBC turbo 400 gearbox with a Nolan transfer 4wd box. Toyota 12000 lb winch, Fiddle brakes leaves on back coils front, 4 point race harness(2) Roll caged . fire ext. PRS, FJ55 diffs floating axle model in rear, 4 wheel disc's. LPG with correct LPG carb. Rear mounted radiator Mongrel 32" tires ( streds Swampers lugs ) Motor needs to be pulled down and oil rings need replacing but I have driven this beast regularly for 6 years as it is and haven't had a problem smokes on start up has good oil pressure and compression
If ya keen I can send pics but cant post them on here directly??
Jeep CJ3 A no job its gotta go !!
Re: Jeep CJ3 A no job its gotta go !!
Go to a website like photobucket and load your photos on there. Once done, copy the link to the photo into your ORE post. Preview the post to check the photo works - sometimes you need to resize the image (under editing tools in Photobucket) to fit.
Keen to see some photos.
