Chrome Molly diff gears
Does any one no if u can get cromemolly diff gears 4 a 4.3 ratio,,,, have seen them for 4.88 but not the 4.3. This will be my 3rd crown wheel in 3 months I've killed
- Still Unbroken
- Bush Crasher
Re: Chrome Molly diff gears
Give Andy a call from Garland Engineering 021991241. Just got some Yukon 4.88`s and I'm sure he has other ratios in stock too.
Oh yup thanks will do what they Cost u?
- Still Unbroken
- Bush Crasher
$600... not cheap but good quality...
Although was just checking Yukon's site and couldn't see 4.33...
Try Lowrange off road.com they have Nitro gears for reasonable price although freight and duty kill it a bit...
Hi,
Just remember if you get Nitro you need to get a new drive flange, $600 is quite a bit.
How soon do you want.
Doing an order from the states soon
Tim
Tim
Hey Tim in no real rush,,,, oh yup sounds good kusum let me no when u want to do a order and ill confirm with u cheers
What engine and gearing do you have? Also it might be that the diffs have been badly set up. I've got 4 toyota 8" diffs and only one of them had all the original side bearing caps. One of the diffs with the wrong cap on it allowed the side bearing to move 0.2mm which is huge for a diff hence why it failed.
Hey i import my gears from East Coast gear supply
http://eastcoastgearsupply.com/i-12009953-nitro-toyota-v6-turbo-e-locker-8-ring-and-pinion-4-30.html
they also do there own brand one in which you dont have to change the flange i went with this option and when they freighted it to me the customs sheet Had a value of $50 so no import tax, total at my door was around 350 with a solid spacer. best to give them a ring and they are more than happy to help.
