3L/5L engine to R151 box?
micahb
Post by micahb »
Is there a bell housing that joins these together? Im guessing the 1kz bellhousing will not fit the L series motor.
If you know which model i need to get (hoping there is one) can you pass on your infinite wisdom?!
Cheers guys!
tweake
Re: 3L/5L engine to R151 box?
Post by tweake »
surf 2.4. you will want the single flywheel conversion clutch as well. hiace pressure plate, hilux clutch plate and surf bearing.
micahb
Post by micahb »
Aewsome, cheers for that.
