Got my surf stuck today in fairly deep mud now the clutch is slipping big time, im guessing this is quite a common problem.
Just wondering have you fellas addressed this in the past?
Clutch slip after getting stuck
Re: Clutch slip after getting stuck
stick the hose in the bell housing,
The_wehi@hotmail.com
(027 788 1046)
Pzj77 Turbo/auto,33's .
(027 788 1046)
Legend thanks
Pump the clutch while your hosing it out.
then buy a new boot to go around the clutch fork.
Chucked the hose in there yesterday then took it for a blat still slipped but could actually drive it down the street, hosed it out again and it had full friction, no slip under full throttle.
Then this morning it slipped quite heavily on the way to work.
And funnily enough the boot is in very good condition.
use a piece of wood to hold the pedal down and leave the hose running in there over night mate
Took a couple of rinses but worked a treat.
