safari diff lock - vacuum troubles
Posted: Mon Feb 03, 2014 5:39 pm
So I've swapped my open rear diff for a factory vacuum locking diff
but am having problems getting the diff to engage/disengage. The diff and solenoids are from a petrol GQ and have been swapped to a diesel.
I have bypassed the solenoids (yep they have a 12v feed) to eliminate them. I've teed into the vacuum post vacuum canister for the diff and have vacuum at the diff.... but possibly not enough. With the vacuum on the 'engage' side of the diaphragm assembly, noting happens (this is with one wheel jacked up) but with a little assistance from the air compressor on the disengage side she locks all good (about 10psi assist) and vice versa when swapped around.
The alternator is a couple of years old at a guess so i'd expect the vacuum supply to be all good, also brakes are fine so no obvious red flags there.
Any suggestions?
Any suggestions?
