wiring diagrams/workshop manuals
So I've found a few available online, but did Suzuki do as a lot of others and change the wire colours depending which factory they came out of? It's a nz New SJ413. Stripped for a Bush truck just trying to tidy up someone's hash up rear battery setup and strip all the unneeded wires so trying to work out what goes where that I need to keep. Found most of it, but the dizzy has yellow and black wires. The black has 2 plugs so I presume that's coil neg and tacho. The yellow is cut and I can't see a corresponding yellow in the body loom. I guess that's 12v. There's a lot of plugs with black and green/red wires that go nowhere would be interested to know what that's from too
