Disco SE electrical issues
Posted: Sun Feb 16, 2014 7:34 am
by 3rnzir
Hi,got this truck to tow a boat.
1st timer with Disco`s.
Anyways,drove 50 odd K`s briefly turned engine off would not start.
Jump started OK.
2 weeks later (went overseas) expecting to jump start it again,motor turn over fine.
Good battery.
Is a sensor getting too hot and the ECU getting signals crossed some how?
Previous owner removed the catalytic fruit from the exhaust system.
Could this be an issue too?
Any good Disco mechanic/tech in the Sth Akld area.
Cheerz
Re: Disco SE electrical issues
Posted: Sun Feb 16, 2014 8:41 am
by kbushnz
start with the basics and remove and clean the battery terminals and check the earth leads.
Posted: Mon Feb 17, 2014 7:45 am
by noexitroad
go to page 3, there is some info there.
keep us informed
Posted: Tue Feb 18, 2014 8:32 am
by 3rnzir
Thanx for the heads up noexitroad.
Sounds like my issue.
Will keep informed as requested.
Cheerz cobber
Posted: Sat Feb 22, 2014 4:23 am
by 3rnzir
I have wrapped some heat deflecting ducting wrap around the ignition module on the dissy to see if that helps.
Posted: Sat Feb 22, 2014 10:56 am
by Cheesy_Dave
3rnzir wrote:I have wrapped some heat deflecting ducting wrap around the ignition module on the dissy to see if that helps.
When I got mine it had a dead ignition module, it had already been relocated from the dizzy to an aluminium bracket on the inner wing. I replaced it with a Jaycar ignition kit which seems to be working ok
Posted: Thu Apr 10, 2014 9:24 pm
by 3rnzir
The reflective wrap seems to be working fine so far.
