Y60 Front axle seal
For all Nissan related topics
klompy
Y60 Front axle seal
Post by klompy »
Does any one know if there is a better after market seal than original.I'm sure I saw a video on you tube and the yank was fitting an after market seal that he had a rave about.If not I will go genuine.
jeremy
Re: Y60 Front axle seal
Post by jeremy »
Are you talking the inner axle seal inside the ball on the housing?
If so ...I heard a rumour that the GQ/Y60 inner axle seals are the same as used on the hilux solid axles. If that is true, these are two options which might work for you:
http://www.marlincrawler.com/axle/front-axle-parts/front-service-parts/service-front-hilux/hd-inner-axle-seal
http://www.trail-gear.com/knuckle-service#node-4725
klompy
Post by klompy »
Yep those are the ones,thanks for that.Does any one know if the hilux ones are the same and if any one in NZ stocks them.
mudtroll
Post by mudtroll »
BNT sell them for approx $10, seem to have lasted ok in my truck. If they are regularly leaking might be a bent diff housing thats causing the problem.
klompy
Post by klompy »
Put a BNT kit in about 3 years ago and drivers side is just leaking,but dont like the job changing them so want something better.
Trundle
Post by Trundle »
can be caused by worn brass bush that the cv contacts on , grooves worn in the axle , or other worn hub components ,
klompy
Post by klompy »
From memory it has a needle bearing not a bush but will have a good look at it all when I strip it down again.
T-mo
Post by T-mo »
I replaced my leaking ones with a Terrain Tamer (sp?) kit I got from BNT. Had no problems with them. You are correct about the needle bearing setup.
I'd give Auckland Bearings a ring (09) 444 6566, that was who I got recommend last time I needed seals, good to deal with.
4WDBits sell the seals too - http://www.4wdbits.co.nz/ProductDetails ... uctID=4120 - If you want to buy OTS.
Genuine seals tend to be more expensive I've found.
Tomo
1991 Nissan Safari AD SWB TD42 - 33x12.5 BFG KMs, 2" lift + more coming.
"Never let a nerd loose with a torque wrench."
4WDbits
Post by 4WDbits »
jeremy wrote:Are you talking the inner axle seal inside the ball on the housing?
We have the Hilux Trail Gear Trail-Safe seals Image on the shelf too: http://www.4wdbits.co.nz/ProductDetails.aspx?productID=4870
I've just put a vernier on the 2 seals side by side and they are almost identical. Next time I do an inner axle seal I'll be trying the Trail Gear Trail-Safe seal.
mudlva
Post by mudlva »
By memory...
O/d is the same Y60 shoulder is 0.75-1.00mm larger then L/C
The L/C seal do fit as i use them rather than Y60 as i was getting a packet of 10 for around $4.50+gst each
When i was running L/C diffs i went through lots of cvs and each time it took the seal out.
Time will tell how the Y60 holds up
Altho i have a set of c/molys to eventually go in once all the spiders have been sorted out :twisted:
3VILC
Post by 3VILC »
Hilux one is also thinner from memory when I've done them but might be useful if you have a groove worn in the shaft that's cutting the seals like mine did
