2.8 Central Locking issues
linz
Post by linz »
Hi All
I have a 1998 hilux and up until today the central locking has been working fine just went out to lock the old horse tonight and no more central locking. Is this something simple or has something burnt out?? Seems strange that it just stopped do they have a fuse? Just wondering if anyone else has come across this before.
Mattman
Re: 2.8 Central Locking issues
Post by Mattman »
There will be a fuse.
Have you tried locking/unlocking from the passenger door?
linz
Post by linz »
No difference if trying from the passenger side.
Fuse is good when putting fuse back into its slot it makes the locking sound like it trying to work but not actually locking or unlocking it.
Relay maybe?? Or some dirty contacts is the main system behind the drivers door card or does each door have its own system
4X4LUX
Post by 4X4LUX »
my central locking stopped working in my hilux (truck got a bit wet in the cab) . had to replace the motors in each door.
Mattman
Post by Mattman »
All doors will have motors with the front two being actuators. If one of the actuators has got wet or is playing up then it can cause issues.
Pull the drivers door card and unplug the actuator and test from the passenger side.
Repeat if necessary on the other side.
catalystracing
Post by catalystracing »
I have a 96 SR5 Hilux LN107, my rear passenger door locking stopped working, its the 12v solenoid that's packed up. Can replace from a wrecker or adapt another solenoid from an auto sparky.
While your at it pull all the door cards and CRC all sliding joints etc and tighten the grub screws that lock onto the actuating arm.
Cheers Paul.
catalystracing
This is the crook one from the rear door, still on its mounting plate.
