Clutch cable
Posted: Sat Feb 22, 2014 7:55 pm
by 3VILC
Is there a trick to undoing the clutch Cable end nut on an SJ413? I presume I'm not the only one where the nuts rusty from being in water mud etc. I did read that the end of the rubber bellows is meant for holding the cable but still the whole cable seems to just turn. Is there a trick, or maybe I should just cut the cable and buy a new one tho these don't seem to come with the nut either. Just need to change the gearbox.
Re: Clutch cable
Posted: Sun Feb 23, 2014 4:31 am
by lilpigzuk
Remove the lever off the side of the gearbox that the cable is bolted to. Remove cable completely or let that end sit in tub of something to soak/penetrate. Wire brush the shit out of it and nail it with wd40 or similar.
Re: Clutch cable
Posted: Sun Mar 02, 2014 11:55 pm
by 3VILC
Got the bugger, doing it in daylight rather than useless lights that need replacing in my garage helps a lot
Quickly realized that pushing the rubber boot back reveals a square crimp in the actual cable
Not the metal ring on the end of the boot like the diagram I found led me to believe
