WTD Hilux transfer box
Selling or wanted vehicles.
specweapon
Post by specweapon »
Bought a project off trademe and now finding out why it was a project. Transfer case is a nightmare to find.
http://www.trademe.co.nz/Browse/Listing.aspx?id=693805771
And to be extra helpful he sold the transfer case seperate to someone else for $1
http://www.trademe.co.nz/Browse/Listing.aspx?id=695635670
Has anyone got a VF1A transfer case or know where I can find one before the mrs kills me for spending too much on a truck I can't even fix?
chrome
Re: WTD Hilux transfer box
Post by chrome »
I will jump on this here, I have a box but dont know how to ID it,
anyone got some tips :D
DIRTY OLD HILUX
022 519 7700
specweapon
http://www.marlincrawler.com/tech/transfercase/transfer-case-bible
At the bottom shows how to tell the difference between the chain drive transfer that I'm after, from the gear drive box.
Compare it to Image
which only has the 5 bolts around the rear cover.
And the one I'm after has the range lever coming out the top of the transfer box, not through the gearbox like later models
bigstu
Post by bigstu »
specweapon wrote:Bought a project off trademe and now finding out why it was a project. Transfer case is a nightmare to find.
Hi could you possibly explain what your gearbox looks like? does the transfer lever have a 4wd button on it? does the transfer lever actually mount into the gear box (forward shift) or is it missing all together because it mounts on transfer case (topshift) I have two w56 topshift transfers here and one g52 forward shift, but kind of had plans for at least one of them in the future.
heres a link to a w56 forsale
http://www.trademe.co.nz/motors/car-par ... 275654.htm
Or your gearbox may also even be the bigger r15* which has a different transfer again.
all I can say is what a dick the guy was for not including the transfers with the truck.
Thanks Stu
Smurf
Post by Smurf »
So you are after a transfer from a W56 gearbox?
specweapon
Hey, I'm 99% sure it's a r150f gearbox, so from a surf more than a hilux.
It's a top lever transfer box, I asked you in your listing Bigstu. Wish I was after a W56
mikeyt1689
Post by mikeyt1689 »
i might have one available for you if is right type pm me
bigstu
Post by bigstu »
specweapon wrote:Hey, I'm 99% sure it's a r150f gearbox, so from a surf more than a hilux.
http://www.trademe.co.nz/motors/car-par ... 681722.htm
this auction is not me its i guy I get most of my parts off I seen you had asked yes yours will be a real strange top shift r150 transfer, my advice would be ditch the old gearbox and get hold of the more modern and easyer to come by forward shift r150 like the one you asked about down here, the wiring from memory is easy to sort from diagrams on the net.
Thanks Stu
specweapon
Yeah that's my next option, looking like it may be the only option, probably cheaper too. Cheers Stu
Smurf
Post by Smurf »
mikeyt1689 wrote:i might have one available for you if is right type pm me
You have w56 transfer.
Im a Tumor
Post by Im a Tumor »
I think i have the box your after.
6 bolts where it bolts to the gearbox. transfer leaver on top.
specweapon
Unfortunately I think you've got a G series transfer box, mine has 9 bolts like http://i1081.photobucket.com/albums/j345/maniac_motorsports/100_2927.jpg
It the chain driven transfer box, cheers
ToyRover
Post by ToyRover »
so what ya after i have r series g series and w series transfer cases but unsure on what u what?
specweapon
The exact transfer is a VFA1, which comes on a R150 gearbox, so guessing that means your r series? Luckily each series is very different so easy to tell the correct one from photos
