argon shield transfer between bottles...
Dace
Post by Dace »
heres the story, when I bought my cebora welder, it came with a free full bottle of argon.... there plan is when i finished it, ya take it back, they then register me and I then start paying rental fees...
But I don't want ta do that...
I like me rental free bottle...
My question is, if i rent a bottle, have a joiner pipe made up that can join my empty bottle to the full rental.... open both taps.... will the argon flow to the empty, given me a 1/2 in each... then i can use whats left in the rental and save my rent free bottle for later???
nismo26
Re: argon shield transfer between bottles...
Post by nismo26 »
You can equalize the two bottles, who owns the current bottle there are places that fill owner bottles.
Dace
Post by Dace »
nismo26 wrote:You can equalize the two bottles, who owns the current bottle there are places that fill owner bottles.
Its a blue BOC bottle... i was surprised when i got it free with my cebora and I'm thinkin when I take it in for a fill, I will start paying rental from that point on.
I haven't asked around to see if the fillers will fill BOC bottles
mudlva
Post by mudlva »
just be real carefully with what ever pipe you choose as the bottles are around 2500psi pressure
Rotazuk
Post by Rotazuk »
And I have heard you need to remove the check valve inside the outlet .
Dace
Post by Dace »
mudlva wrote:just be real carefully with what ever pipe you choose as the bottles are around 2500psi pressure
I was gonna use drink straws from maccas!!!
na, seriously, thanks for the heads up, im gettin it made by local hosing company, and they know what its for
Dace
Post by Dace »
Rotazuk wrote:And I have heard you need to remove the check valve inside the outlet .
i thought there might be something like that in there.... will keep in mind
nismo26
Post by nismo26 »
I don't think they will fill it if it is a BOC bottle. Is it stamped with NZIG or Boc, if it isn't you might be able to get it filled.
tallsam66
Post by tallsam66 »
Be super careful ....your tinkering with a bomb .... it the pipe your trying to Cpl them with ruptures you could get killed.
Dace
Post by Dace »
will do, as i said its getting made by a hose specialist who will know its to be used for
catalystracing
Post by catalystracing »
Used to do it at work from the G size to D size, tho it was kinda shhhhhh make sure no ones looking :shock: :wink: :lol:
slide
Post by slide »
[quote="nismo26
I don't think they will fill it if it is a BOC bottle. Is it stamped with NZIG or Boc, if it isn't you might be able to get it filled.[/quote]
Bit of bog to cover the stamped writing, then a repaint of bottle?
or not that simple?
Trench_rat
Post by Trench_rat »
can you please set up a camera when you do it so if it goes wrong it can a) be used for identification purposes , and b) a warning to people not to #### with shit they shouldnt touch. would you try defuse a hand grenade or leave it to the pros?
Its ok Dace doesnt need his other hand or legs :lol:
Leave everything to me in your will please bro ;-)
stinky
House Hubby
Post by stinky »
To be honest I like your drinking straw idea the best
____________________________
Martin
http://www.wtbs.co.nz
UBZ
Post by UBZ »
If its a BOC bottle , the guy you got the welder from, should logically still be paying bottle rental to BOC ..... Id ask him if this is the case .
My experience with BOC is that they normally pursue their bottles as stolen, if an account is closed .
Current BOC bottles normally have a printed Bar-code tag attached to the neck of the bottle.
Private bottles older than a certain number of years (cant remember) need a safety test certificate ( /sticker ) before they can be filled . $$$
you can drain one to another , you tip the full bottle upside down and open the purge valve on the empty bottle untill fluid comes out. (but as other have said its a very dodgy thing to try and do). Gas /Fulid under that sort of pressure can enter your body directly through the skin and cause extremely dangerous gas bubbles in your blood (bit like the bends)
likemagic
Post by likemagic »
with LPG I use to put the bottle I was going to refill in the freezer for the night, you get more in.
Maurice
Maurice
KZN185, 1KZTE running needing birthday
Return to “Tool Shed”
