I have a small hole in my radiator.....
Taha32
Post by Taha32 »
I have found a small leak in the radiator in my hilux, where the rubber hose
connects. I was wondering if anybody would recommend a place to get it fixed in Chch? I think it just needs to be soldered.
Regards
Tom
Andygoodbloke
Re: I have a small hole in my radiator.....
Post by Andygoodbloke »
A1 radiators on St Asaph st.
You can take the radiator out and take it in, and may consider a flush while you are there, or if feeling rich or busy, take the vehicle in, advise of the problem and come back when they say
They are top people, and even custom make intercoolers, oil coolers etc and where other radiator shops go for parts
callum007
Post by callum007 »
open the top, crack an egg in it. breakfast sorted!
Campbell.s
Post by Campbell.s »
Hornby radiators is a good shop we take all your rads there from work
oldyella
Post by oldyella »
I had this exact problem with my FJ40 cruiser radiator modified to fit into in my V8 Landrover.
It was cracked at the top where the hose connected. I brought a small butane gas torch (pen style but was also a gas powered soldering iron for $15 or something) and just heated up the radiator enough to melt / flow solder onto it.
Worked bloody good.
A while earlier I had it repaired prior to fitting for only $30 or something but it cracked again :roll:
I wouldn't try the same method if the crack was on the side or bottom. Dam gravity. But you could always remove it and give it a go.
derk
Post by derk »
yep done as above ^^^ a few times in the past but with the price of radiators these days unless the radiators not very old and in reasonable nick I scrap them and shove a new one in :D
oldyella
Post by oldyella »
Wasn't until after the repair I realized how awesome a trail fix this is. Torch & solder lives in the spares box on the back now :wink:
