Smoking 1hdt
a80crewza
Smoking 1hdt
Post by a80crewza »
My 80 series is smoking quite a bit at start up and under acceleration. Smoke looks to be greyish, and its letting off a strong diesel smell. Does not seem to be using oil. It IS leaking a small amount of oil though. Cheers.
philux
Re: Smoking 1hdt
Post by philux »
Unburnt diesel, lots of diesels engines do it, if its black it is getting a bit excessive.
DMcCready
Re: Smoking 1hdt
Post by DMcCready »
Sounds like you need to get your injectors serviced
There's gotta be some rocks round here SOMEWHERE!
imsohi
Re: Smoking 1hdt
Post by imsohi »
Or blocked air filter, thats where i would start, have you just brought the truck or has it just been getting worse? lost any power? black smoke usually means over fueling make sure someone hasnt uped the boost and tweked the pump then sold it to you back at std boost without changing the pump again. does it smoke on boost or just off it? Most knowledgeable person closest to you would be Nathan @ Kaipoi Repowers he knows his diesels well.
