Am going to be fitting a cooler to the cruiser and Im just wondering if it matters which way up the cooler is mounted eg inlet and outlet pipes at the bottom or the top?
Does it make any difference?
1hd-ft Intercooler question
Re: 1hd-ft Intercooler question
Heat rises so I guess hot side on top would be the best way as the heat will rise up and away from the cold side.
