Details:
Running standard temp thermostat 82 degrees
Aftermarket 3 core alloy radiator single pass
16 inch 2100cfm fan mounted on front of rad (spinning correct way)
External trans cooler doesnt flow through rad at all
50/50 mix coolant
Factory ecu/ new genuine ecu water temp sensor
Aftermarket digital fan controller set on 92 off 86
All the following is based on 25 degree approx days
When driving on open road the rad is more than efficient enough to cool properly temp sits at approx 85-88 without the fan running.
When town driving approx the 90 degree mark and 92 when doing stop starts. The fan comes on at 92 and then coolant quickly drops to 86.
On the tracks is where the issues come up. low range up to 20kph approx.
The fan will keep up longs as i'm not climbing hills for more than 10-15 mins then temp will climb up to 105 maybe more but i stop moving and idle till it drops down again.
On flat stuff the fan will also keep up approx 90-94 as long as the radiator is fully clean but as soon as anything gets on the rad ie mud leaves etc even as little as 15% blocked then will begin to climb and then the fan cant keep up.
Here is some pics of current set up:
My plan is to move the radiator forward to where the radiator support is
Mount fan on back of radiator as there will be room now and hopefully be able to get a shroud made up also. and look as a way to make a removable screen to catch debris that can be taken out and washed anywhere
Now this is where i need your opinion/ experience:
To move the rad forward will mean i need to get a custom radiator made up as the current one is too tall because of the chassis cross-member and the bonnet
1- Will making the radiator 15% smaller height-wise cause more issues?
2- Will getting a triple pass radiator also help with more cooling?
3- Will setting up a coolant tank say 10L in line with radiator pipes to add capacity help at all? if so where would be the best location to put this inline be?
4- Will 1 16 inch fan or 2 10inch fans be better if total cfm was same as the 16 inch fan?
5- Is there a magic spacing measurement between radiator and fan when using a shroud?
6- When using a fan switch sensor is it better to be in the bottom tank of the radiator seen your trying to control the temp heading back into the motor?
7- How much difference would adding a oil cooler make to engine temp at slow speeds?
I know its a lot of questions but a custom radiator is not cheap so only want to to get made once.
I would like to stay away from adding vents to bonnet if possible as sometimes this can make it better at 1 speed but worse at another.
What is your opinion/ experience on issues with sorting out hot water temps?
feel free to ask more questions if need be
