Refiting water pump
brakes-shocks-lockers-etc
dazza85
Refiting water pump
Post by dazza85 »
I'm doing up the moter and have the full gasket set and when refitting the water pump want to know what you folk use on the gasket or do you refit it dry ?? :?: :?:
mud_slinger
Post by mud_slinger »
i have never used gaskets before, i jus cover it in sealant and it does the job fine
needs more curry
0272593533
wopass
Re: Refiting water pump
Post by wopass »
dazza85 wrote:I'm doing up the moter and have the full gasket set and when refitting the water pump want to know what you folk use on the gasket or do you refit it dry ?? :?: :?:
i allways put a thin film of gasket goo on both sides of the gasket when i do a water pump as the last thing i wanna be doing after i run up an engine to pressure test the coolant system...is have a f#%king leak on the water pump that ive just replaced.
