Steering shaft mod HELP!!
For all Isuzu related topics
Xr246
Post by Xr246 »
Need to lengthen my steering shaft on my Isuzu MU
Whats the go with doing it legally?
Just take it to a engineer with a welding ticket get the paper work then get cert?
I have a 3" body lift and need to lengthen the steering shaft to make it all work
derk
Re: Steering shaft mod HELP!!
Post by derk »
nope
can you bolt a spacer in somewhere how much extra length do you need, 3" is a pretty big bodylift :shock:
Xr246
Post by Xr246 »
Na no way i can put a spacer in. Not like a toyota shaft
Its got prado diffs front and rear and the spring/strut comes up past the chassis so lifted the body to get clearance. With 3" its only just enough to get the body back on.
Mattman
Post by Mattman »
Can you cut the inner guards and lower the body?
Don't believe you can cert welded steering pieces.
mudlva
Post by mudlva »
Find a longer shaft and get it shortened would be a better at a guess
Smurf
Post by Smurf »
Would a Bighorn column be any longer?
Xr246
Post by Xr246 »
Mattman wrote:Can you cut the inner guards and lower the body?
Yea i can cut the front guards to get the body lower. It use to have no body lift and the front guards cut and the floor in the rear chopped to fit the rear suspension thru. Ive taken the old body off and scraped it and put a tidy body on
I don't want to cut the new body up as i want back seats. maybe its not possible
Xr246
Post by Xr246 »
Smurf wrote:Would a Bighorn column be any longer?
Not sure does anyone have one they can measure?
Have only tired a wizard column
Return to “Isuzu”
