Hey, does anyone know of anyone in New Zealand who sell alloy radiators with incorporated trans cooler for a 97 tj wrangler?
Cheers.
alloy radiator
Re: alloy radiator
Any particular reason you want to run alloy? I got one from Adrad it's copper and brass. Perfect fit and made in Australia for RHD TJs.
Re: alloy radiator
I got mine from http://www.trevormorrisradiators.co.nz/ about 18 months back
Seams well constructed... and lined up perfectly...
Temp doesn't move... even under load
Not alloy... but all metal... (No plastic tanks top or bottom)
O[][][][][][][]O
Eat, Sleep, Jeep...
www.nzjeepclub.co.nz
Eat, Sleep, Jeep...
Re: alloy radiator
00falcon wrote:I got mine from http://www.trevormorrisradiators.co.nz/ about 18 months back
I got mine from them as well. Probably the same thing. No plastic pieces in mine.
Re: alloy radiator
Thanks guys.
I only wanted to go alloy because I didnt realise you could get others all metal.
Mine at the moment has been hit with so much shit the fins are nearly non existent in parts and now I have a winch sitting on the front its starting to get a bit warm.
Re: alloy radiator
http://www.summitracing.com/int/parts/p ... /year/1997
All you have to do is swap the side brackets out for your RHD ones on your current radiator.
Re: alloy radiator
That one has plastic top and bottom tanks like factory. There one from TrevorMorris is AdRad's brass and copper with no plastic. Also brackets are welded on and fit perfectly.
