td27 crank sensor
Posted: Sat Mar 29, 2014 9:33 am
by sionline
I'm trying to locate the crank angle sensor on my TD27 (ETi) can anyone point me in the right direction? Cheers.
Re: td27 crank sensor
Posted: Sat Mar 29, 2014 5:31 pm
by Crash bandicoot
top of bell housing behind rocker cover on the intake side according to the workshop manual.
http://bebrs.pie-dabas.net/Webs/Terrano/R20/ec.pdfpage 385
Posted: Sat Mar 29, 2014 6:05 pm
by ChurchurDan
They are in the front timing cover between the alt and water pump. The loom plug in on the inlet manifold and goes around the front of the rocker cover and down past the alternator.
Never seen one in the bell housing Crash but I don't see many Menstrals either (they may be different everthing else on them is), everyone around here has Terrano's
Posted: Sat Mar 29, 2014 6:17 pm
by Crash bandicoot
yeah sorry should have asked what year and what chassi the motor is in.
Posted: Sat Mar 29, 2014 10:21 pm
by ChurchurDan
That diagram puts it in the bell housing above the starter. Very interesting as I have never seen a TD of any flavour with a sensor down there. The diagram is for A td27ti, Do you know which pump they have Crash?
Posted: Sun Mar 30, 2014 6:34 am
by Crash bandicoot
ChurchurDan wrote:That diagram puts it in the bell housing above the starter. Very interesting as I have never seen a TD of any flavour with a sensor down there. The diagram is for A td27ti, Do you know which pump they have Crash?
yeah the one i just ripped out off mine in favour of the older mechanical pump. the Covec fly by wire needle valve.
Posted: Sun Mar 30, 2014 9:03 am
by ChurchurDan
Zexel Covec or Bosch?
I still can figure why it would be in a different spot. Maybe the Spaniards just have to be different
Sorry for the thread hijack Sionline
Posted: Sun Mar 30, 2014 9:27 am
by sionline
Thanks heaps for your help I really appreciate it
First time google and you tube have let me down ever !
Nice work, thanks
Posted: Sun Mar 30, 2014 11:34 am
by sionline
ok located and removed thanks for the tips, looks like repco have supplied me with the wrong part to replace it, guess I'm riding the Buell to work tomorrow !
Posted: Mon Mar 31, 2014 6:29 am
by ChurchurDan
Go see your local auto sparkie we can get genuine sensors cheaper than Nissan from memory they are about $180
Posted: Mon Mar 31, 2014 5:30 pm
by sionline
Thanks Crash and ChurChur looking forward to winter now and...MUD
Posted: Mon May 26, 2014 6:49 pm
by travis2ninja
Hi all,
Got a question with the engine revolution sensor.
I put a TD27 out of a navara into my terrano and on the terrano its located under the injector pump but on the navara its located on the front between water pump and alternator.
I have cut and made the wire longer to reach the plug, but it is not working?
Is their a difference between the two?
Posted: Mon May 26, 2014 7:00 pm
by Crash bandicoot
travis2ninja wrote:Hi all,
yes ones a crank angle sensor for the ECU/EGR and is a positive, the one below the I/P is a negative on the earlier td but is converted to a positive on the later TDI but that same sender is on the actual I/P
Posted: Mon May 26, 2014 9:59 pm
by travis2ninja
So if that same sender is on the injection pump. Which one does the tachometer use?
Posted: Mon May 26, 2014 10:21 pm
by Crash bandicoot
travis2ninja wrote:So if that same sender is on the injection pump. Which one does the tachometer use?
the tachometer gets its signal from the IP side of the engine regardless if it is on the timing gear cover or the injector pump it's self, either way you still need a signal converter of some sort.
