304 AMC V8, Borg Warner T18A four speed manual gearbox (6.09:1 crawler first gear) with Dana 20 transfer case. Dana 44 front and rear diffs with Detroit locker in the rear.
Rolling on 38 x 15.5 x 15 Parnelli Jones mud grip tyres mounted on 15 x 10 rims.
Comes with full length hard top ( needs fibre glass repair), ute hard top and new bikini soft top. It has a set of full doors as well as a set of soft half doors.
Spring over axle conversion, disk brake fronts and drum rears.
HEIU dizzy.
Single 3" exhaust. Very nice sounding rumble to it.
Pair of comfortable jap bucket seats fitted.
Reg on hold, no WOF, certed for mods.
Near new EFS extreme shocks fitted just before it was put into storage.
Has been sitting in my shed for the last 5 years.
Needs twin stick conversion on transfer case sorted. Only selects low range and 2wd/4wd. High range is selectable when I had the transfer case out so it is the selector levers not the transfer box that is the problem.
Recon gearbox, has not been used since re-installation (can probably find the receipt if required).
Comes with a few spares. gearbox, some lights, drive shaft etc. see photo.
Has a chip in windscreen that will need fixing if going to put back on road and a new handbrake cable. Clutch needs a good bleeding as well.
PM me if interested in viewing or if you have any further questions.
Photos at:
https://www.flickr.com/photos/124424360@N03/with/13980109320/
TM auction:
http://www.trademe.co.nz/Browse/Listing.aspx?id=728555349&ed=true
